Re: farmall M--weights vs. fluid
Posted by old on November 24, 2007 at 09:16:33 from (4.244.186.131):
In Reply to: farmall M--weights vs. fluid posted by zooeyhall on November 24, 2007 at 09:10:16:
Each have there good and bad points. Weights are sort of easy to change out if your real strong that is. Fluid puts the wiehgt right on the tread of the tires not on a cushion of air so I my self feel the fluid works better most of the time. As for as the problem of rim rust I use Wind shield wiper fluid in my tires now days. It will not rust the rims, plus if it does leak it will not kill the grass for years to come and also doesn't freeze. It does cost a little bit more to put in but it you watch you can get it on sale for a little bit more then a buck a Gal.
Today's Featured Article - History of the Cockshutt Tractor - by Danny Bowes (Dsl). The son of a very successful Toronto and Brantford, Ontario merchant, and himself quite an entreprenuer, James G. Cockshutt opened a business called the Brantford Plow Works in 1877. In 1882, the business was incorporated to become the Cockshutt Plow Company. Along with quality built equipment, expedious demand and expansion made Cockshutt Plow Works the leader in the tillage tools sector of the farm equipment industry by the 1920's. ... [Read Article]
