Re: F-20 cylinder sleeve removal - help
Posted by Loren in Iowa on November 24, 2007 at 17:04:01 from (207.177.2.187):
In Reply to: F-20 cylinder sleeve removal - help posted by Scott Rukke on November 24, 2007 at 16:46:33:
Heat and vibration works on stubborn sleeves. Heat the sleeve up with a cutting torch, and rattle it, from the bottom, with a blunt attachment on an air chissel.
