F-20 cylinder sleeve removal - help
Posted by Scott Rukke on November 24, 2007 at 16:46:33 from (67.183.230.71):
The sleeves won't budge. I even have a bottle jack mounted in the crankcase against a plate bolted to the bottom of the engine and the sleeves will not budge. Any suggestions?
