Out of desperation I inverted the block & placed a oak block across the sleeve end. Then took a 20lb piece of shafting and started pounding. All four sleeves bumped out easily. The rapping apparent works better. I was worried about cracking the top deck or the lower web, but turned out OK. Should work with a 16lb hammer too.
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
