It is a clever re-use of an obsolete vehicle. Looks like alot of skillful engineering and applied imagination. It really isn't much different than converting an old mill building into apartments. Or building a hot rod from an old car. Isn't that alot better than destroying both. The tractor was probably saved from a slow death in a salvage yard. Let's face it, there are plenty of old Farmalls and parts to go around.
On another level, I like it because I am building an ice cream making and serving tractor from my Electrall equipped 400. It will still be a fully functional tractor when the ice cream hardware is removed.
Heck, I should bid on that item. I probably couldn't build one cheaper. But how do I run both tractors at the same time? Uh oh, I smell vanilla ice cream, bar-b-cue ribs, bigger truck, and a payroll coming on.
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
