Re: High oil pressure
Posted by High Octane on November 25, 2007 at 06:14:54 from (4.224.78.213):
In Reply to: High oil pressure posted by WonderingAl on November 24, 2007 at 21:44:16:
If it has live hyd,,, Id be checking the cam gear. They do come loose and can slap the timing cover, bust off a tooth, and sound like a rod knocking. Also, pull the valve cover, and the lifter pan, pull the lifters out, make sure they are good, might have one that has a nick/bad spot, and can make some noise. Could be oil pump gear, could be a piston hitting the head,, say they put a new overhaul kit in it,, from a 450,,, if the SM had the old style head, with the new style pistons,, (from a 400-450) the domes will hit the older heads. The 400-450 domes are wider than the M-SM pistons with the older gas heads,,, Also, could be the little part, that holds the lifters from falling out,,, it could have been bent, or put on backwards and slap the lifters,,, High oil pressure,,, best to check the relifef valve inside the pump,, see if the piston, spring and ball is freely moving, could be sticking and shoot the oil pressure up,,, this can also overwork the pump,, causing the gear to loosen, overstessing the cam in its bearings, and possibly wiggling the cam gear loose,,,, Id pull the head and pan off, and the timing cover and have a closer look. JMHO
Today's Featured Article - A Question for Dads This recent topic from the Tractor Talk discussion board is being highlighted because it is an awesome display of the caliber of individuals that have made this site their own. The young person asking questions received positive feedback and advice from total strangers who "told it like it is" with the care many reserve for their own kids. The advice is timeless... so although it isn't necessarily antique tractor related, it will be prominently displayed in our archives to honor those who have the courage to ask and those who have the courage to respond in an honest, positive manner. ... [Read Article]
