Re: 46 A Carb Problems
Posted by old on November 25, 2007 at 08:24:56 from (4.245.6.238):
In Reply to: 46 A Carb Problems posted by Aj Clark on November 25, 2007 at 07:31:09:
Well first off did you just open it up and try to clean it or did you put a kit in?? You need to go the lit route. Then if you did put a kit in did it have a rubber tipped float needle?? If it did you need to take those and seat the needle or they will leak most of the time and cause flooding. You seat them by tapping in the needle with the float out but the needle in the seat. Aslo you need to make sure the needle seat is real tight or they leak. Setting the float lower doesn't help most of the time it hurts because it doesn't have enough gas in the carb to run the engine. Also does choking it help or hurt. If it helps you probably have a clogged main jet if it hurts then you have a problem with the float seat or float
Today's Featured Article - Harvestin Corn in Southern Wisconsin: The Early Years - by Pat Browning. In this area of Wisconsin, most crops are raised to support livestock production or dairy herds in various forms. Corn products were harvested for grain, and for ensilage (we always just called it 'silage'). Silo Filling Time On dairy farms back in the 30's and into the first half of the 40's, making of corn silage was done with horses pulling a corn binder producing tied bundles of fresh, sweet-smelling corn plants, nice green leaves with ear; the ... [Read Article]
Latest Ad: 2022 John Deere 5045E, 4wd, front end loader and 3rd function with grapple. 120 hrs, 55k new, must sell [More Ads]
