Re: High oil pressure
Posted by Andy Martin on November 25, 2007 at 09:37:36 from (63.99.111.188):
In Reply to: High oil pressure posted by WonderingAl on November 24, 2007 at 21:44:16:
Since the SM has a bypass oil filter, it was very unlikely a plugged oil gallery. I have always found that high oul pressure was from a bad gauge.
The bang and knock is probably unrelated but must be investigated and probably warrants disassembly. It may be as simple as a bent push rod, but you don't know until you look.
By the way, oil should only come out the lower petcock, but too much oil will not have damaged your engine.
