Re: ATTN: ENGINE BUILDERS! Red Power 140 Pistons, 2nd time a
Posted by scott#2 on November 25, 2007 at 10:40:59 from (151.200.254.48):
In Reply to: Re: ATTN: ENGINE BUILDERS! Red Power 140 Pistons, 2nd time a posted by Brian Schmidt on November 24, 2007 at 21:30:19:
Brian,
I havent tried a trial assembly yet, I'll just do the old clay trick to make sure domes dont hit and valves dont hit the domes, etc. I called Case and they get 250$ per hole, pist, pin, clips, rings, cylinders, no o rings. Pure insanity. I would say that Red Power kits are "ok", not great though. Check and double check everything. I found some chaff on one of the main bearings oil holes that needed to be cut off. No doubt it would have come off at some point when the engine was running and scored that main set up. CHECK AND DOUBLE CHECK ALL ENGINE COMPONETS.
scott#2
scott
