Re: Hugh MacKay and other Farmall A gurus
Posted by HendrikKRTC on November 25, 2007 at 11:37:18 from (84.85.78.15):
In Reply to: Hugh MacKay and other Farmall A gurus posted by tn terry t on November 20, 2007 at 19:36:40:
I recently reassembled the final drives of my Super A. The inner and outer bearing are common ball bearings. The large outer bearing holds the axle in place, hence the large spacer bushing between outer bearing and bullgear is important for that and it all being snug and tight is key!
Drop me an e-mail if you need more information or pics (oilpan is still off).
Regards, Hendrik from The Netherlands.
