Re: Is it a leak or a weep hole - Farmall H
Posted by CNKS on November 25, 2007 at 14:21:38 from (216.144.104.128):
In Reply to: Is it a leak or a weep hole - Farmall H posted by Jim Isler on November 25, 2007 at 13:39:17:
It's not a weep hole, likley corrosion finally got to it.
Today's Featured Article - Talk of the Town: How to Remove a Broken Bolt - by Staff. Another neat discussion from the Tractor Talk Discussion Forum. The discussion started out with the following post: "I have an aluminum steering gear housing with a bolt broken off in it. The bolt is about a 3/8" x 1 1/2" bolt. I've already drilled the center of the bolt out with about 7/64" drill bit the entire length of the bolt. Only one end of the bolt is visible. I tried to use an easy out but it wasn't budging and I didn't want t ... [Read Article]
Latest Ad: 2022 John Deere 5045E, 4wd, front end loader and 3rd function with grapple. 120 hrs, 55k new, must sell [More Ads]
