Re: Gas $$$$ at $4.10
Posted by gene bender on November 25, 2007 at 15:09:39 from (67.55.226.214):
In Reply to: Gas $$$$ at $4.10 posted by Coax on November 25, 2007 at 10:35:47:
You need a new vehickle that has been built for e85 you sure dont use it in older engines but you can run the 10% blend. Chech your owners manual there has been trouble when trying e85 in engines not built for it.
