Posted by Mike CA on November 25, 2007 at 17:26:15 from (67.126.232.251):
Here are a couple pics of my sediment bowl. The fuel was very slowly coming out of the 'OUT' end when I had the shut off completely closed. I even wrenched it down, but no luck. The fuel kept seeping through.
Here is a bad pic of where the valve sits in.
And here is the valve. As you can see, there is some slight wear in the tip, but I can't see that it made a groove. Also, if I understand what people have told me, there is supposed to be something in the nut behind the part that screws in to the top? I honestly can't figure out why something needs to be in there, and why it would cause a leak if it wasn't there.
Any ideas on what to do about the leak would be greatly appreciated.
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
