Re: My leaky sediment bowl
Posted by ScottyHOMEy on November 25, 2007 at 17:46:40 from (71.241.213.254):
In Reply to: My leaky sediment bowl posted by Mike CA on November 25, 2007 at 17:26:15:
I don't see a groove , Mike. What I see is wear on the high spots . That's where it IS sealing. If you have a leak on that surface, it's flowing over the shiny spots. The dull ones are where you are sealed.
Not all that atypical for such a valve.
Yes, there should be "something" inside the nut behind it all. It's called packing. Easiest to find and most common is a soft rubber rope with a metallic looking covering that you can wrap around the shaft. Some folks use O-rings.
However you go about it, packing will help solve your problem.
Today's Featured Article - The Fordson F Ignition System - by Anthony West. A fellow restorer contacted me earlier this year asking for some help and advice on a model F that he was restoring. He had over a period of months spent a fair amount of his hard earned cash on replacement parts for the old "trembler" ignition. Sadly though all his efforts seemed to be a waste of time and money as he still couldn''t get the temperamental old thing to run correctly!! If i said that this was a little frustrating for him that would be "conservative" in fact the problem had reduce ... [Read Article]
