Re: Started 450D Ran Good Then???
Posted by AJB450 on November 25, 2007 at 21:47:19 from (70.105.97.245):
In Reply to: Re: Started 450D Ran Good Then??? posted by eric and his farmall 450d on November 25, 2007 at 16:29:02:
Eric, My 450-D did something similar once. After starting it and switching it to diesel, it started to run fast and ping badly. I suspected the carburetor float stuck. Shut the gas valve off on the tank and it ran fine on diesel. Tapped on the carburetor, turned the gas back on and no problem with it for the last two years. I suspect that if the float sticks, gas vapor can still get into the combustion chamber and cause this problem or maybe if the butterfly in the intack manifold doesn't close tight, gas vapor can get in when running on diesel side. Anyhow, since you say this problem started when you opened the gas valve, I would check these two items.
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
