Re: Farmall H hydraulic conversion
Posted by Nat 2 on November 26, 2007 at 07:23:41 from (64.80.108.53):
In Reply to: Farmall H hydraulic conversion posted by DickelDawg on November 25, 2007 at 16:44:57:
You don't want to use the belly cavity as a reservoir. The clutch is in there, and it's a dry clutch. It won't take well to floating in a pool of oil.
All you need to go live is a live pump, any old oil tank, and an open center spool valve. It doesn't have to be a Super H tank.
The problem with a Super H tank is it will interfere with the battery. That's why they moved the battery back under the seat on Super Hs with the live hydraulic setup.
