Re: Farmall Crankshaft
Posted by old on November 27, 2007 at 07:43:50 from (4.244.186.88):
In Reply to: Farmall Crankshaft posted by WonderingAl on November 27, 2007 at 07:00:58:
Any good machine shop should be able to help you. You can also check at your local auto parts stores some of them have there own machine shops or can tell you where to take the stuff
