Posted by glennster on November 27, 2007 at 08:44:20 from (76.224.26.7):
In Reply to: Farmall Crankshaft posted by WonderingAl on November 27, 2007 at 07:00:58:
figgure 30-40 dollars to cut the flywheel. the starter gear is easy to change if you have access to a cutting torch, turn the flywheel face down, gently heat the gear in 3-4 spots around the ring, tap it and it will fall off. you can get a new ring from this site, or if yours isnt wore more than half way thru the teeth, you can flip the gear over and put it on the other way. generally a crank cut will run 100 to 300, depending on how bad. have them check the cam lobes and bearing surface. i would have the engine block hot tanked to clean it all up and new cam bearings installed. the machine shop can do all that for you.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
