if you are doing the live pump on the m use the cam drive gear from the super m. it is a lot heavier gear than the old m had, the old gear wont handle the pump and after a while it will let go. been there done that. you dont need to change the camshaft for the live pump. if you dont change the front engine timing cover, you can plug the top two mounting holes with grade 2 bolts, cut them off flat with the cover, then mount the live pump using the bottom 2 bolts, and redrill and tap the top 2 bolt holes in the cover. dont drill thru the cover tho!!
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
