M charging
Posted by henryv1111 on November 28, 2007 at 16:31:35 from (64.81.231.196):
Mr John: Thanks for all the help you have given me in the past. I started the tractor and no charge I checked all the grounds first. I grounded the field and it charged I took the ground off and it worked ok the H/L switch increased or decreased the amp rate ok. after 10 min it quit chariging again. this time I jumpered around the C/O and it started charging again. It looks like the C/O is bad. WIll any 6V C/O work I tried the IHC dealer but they said I have to get a Volt Reg. What ype of C/O is available
