Re: I'll let you all troubleshoot this one.
[ View Follow Ups ] [ Post Followup ] [ Return to Farmall & IHC Tractors Discussion Board ]
Posted by Bob M on February 23, 2000 at 07:04:01 from (192.232.120.194):
In Reply to: I'll let you all troubleshoot this one. posted by The Red on February 23, 2000 at 06:19:18:
I think you and MikeH hit the problem on the head. I've run into the same thing - fresh gas slowly dissolving varnish/crud in old gas tank, line and pump and messing up the carb. Verify by running with a temporary gravity fed tank (borrow the tank off your riding mower or something...)
If that's indeed the problem, figure on removing and steaming/caustic washing the gas tank. Also figure on cleaning or replacing the fuel line and pump - they're probably loaded with green stuff.
Post A Followup
: Re: Re: I'll let you all troubleshoot this one.
