Re: New Farmall H owner with questions
Posted by Wayne from MN on November 30, 2007 at 09:09:30 from (66.228.243.49):
In Reply to: New Farmall H owner with questions posted by RockyMO on November 30, 2007 at 08:52:36:
Likely the end of the shift lever is worn and needs either: 1. remove, buy new, & replace or 2. remove, weld up, grind to shape, & replace.
This is a common problem with 50+ years of shifting wear.
