Re: New Farmall H owner with questions
Posted by Ksfarmmer on November 30, 2007 at 09:13:50 from (24.255.244.98):
In Reply to: New Farmall H owner with questions posted by RockyMO on November 30, 2007 at 08:52:36:
We never had an "H", but I assume it is no different than other Farmalls. Pull the gear shift lever off and you'll see three slides that push the transmission into the five forward gears and reverse. Normally what happens is two of the slides have moved and, as you thought, locked the transmission in two gears. Using a large screw driver you can usually get the slides back to the neutral position. If it continues to happen, you probably need to build up the end of the gear shift lever so it doesn"t allow two gears to engage at once. It is a common problem, the archives should have more info.
