Re: 1940 H engine will not slow down to idle
Posted by tackhammertime on December 01, 2007 at 11:15:07 from (70.144.97.163):
In Reply to: Re: 1940 H engine will not slow down to idle posted by Janicholson on December 01, 2007 at 10:14:14:
The pin on the gov rod is between the 2 ears on the butterfly. When I first got this tractor when you let out the clutch is 5th gear it would about give you whiplash taking off then engine speed would die off as you started rolling. It seems to be running good. But the hole in the end of the gov rod is much bigger than the end on the carb is this ok.
