Starting in fifth is pretty hard on the clutch, and I recommend a shift from 4th to fifth. Make it a slow shift, and it will grind just a little. It is best to double clutch it. Idle down as you pull it out of 4th, then let the clutch out briefly, push in the clutch and then slip it into high. This is hard to do unless practiced. Are you positive you have the carb and governor coupling together at the carb connection, it is tricky little metal fingers, and causes related problems, some of which sound like yours. JimN
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
