Super H, In too deep
Posted by GeneMO on December 02, 2007 at 06:06:03 from (216.74.196.145):
Well this has turned into a way bigger project thatn i planned, but so goes it.
From the bottom I could see one of the 6 bolt on the clutch was twisted off so I decided to split the tractor. So the clutch is out and I am glad I looked into it. The clutch lining is worn down to the brass rivets on one side. No big problem, I can fix that.
My real concern is the flywheel. On the clutch bearing surface of the flywheel, you can see tiny cracks that are about 1/32 of an inch deep. The are about as deep as the that slight bevel if that helps. My question, How much can be taken off with a lathe? Is this common to see?
Thanks, Gene
