Re: Bitten hard by bad Magneto
Posted by Noah W on December 02, 2007 at 08:29:00 from (66.44.252.19):
In Reply to: Bitten hard by bad Magneto posted by chuk davis on December 01, 2007 at 14:15:49:
IGNITION VOLTAGE OUTPUT TEST from Bubba's garage
Scopes may be inaccessible from time to time, so we at "Bubba's Garage"
have come up with this here test for Ignition Output:
1. Hold medium wrench in one hand, Sears wrench preferred for accuracy of test 'cause other smooth wrenches are too slick for throwin'!
2. With engine runnin', grab hold of the plug end of an ignition cable with the other hand and hold on tight!
3. This will more than likely cause you to throw wrench! KV output is based on far the wrench wuz thrown!
* 10 feet = approx. 10,000 volts
* 20 feet = approx. 15,000 volts
* 30 feet = approx. 25,000 volts
* Over 30 feet = Caution! Must be one of them new dis-is-it ignition systems, use bigger wrench and retest.
WARNING! No side effects have been reported due to testing at this time
(although it has been known to kill chiggers after berry pickin')
Bubba Sez: Electricity will not usually hurt you, instead it is the back o
