Re: Farmall M Pistons
Posted by WonderingAl on December 02, 2007 at 11:42:11 from (66.245.113.98):
In Reply to: Re: Farmall M Pistons posted by randy hall on December 02, 2007 at 11:22:47:
If ypou do go to the dome piston or the other you mentioned do you have to use the higher octane gasoline? Or is regular gasoline just as good? What is the standard horsepower of the M with the factory type pistons? What does it become with the domed pistons? And what does it become with the highest compression pistons possible for that engine? thanks.
