Re: Farmall M Pistons
Posted by RustyFarmall on December 02, 2007 at 13:59:55 from (216.248.71.93):
In Reply to: Re: Farmall M Pistons posted by WonderingAl on December 02, 2007 at 11:42:11:
The M was rated at 36 horsepower from the factory. The 4 inch overbore kit with the step head pistons will usually gain 10 horsepower for a total of 46. A little more tweaking and some easy mods and you will be getting close to 50 to 55 horses. Any increases in power after that start to get a bit more pricey, and the results are limited only by how much money you want to throw at it.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
