How much play?
Posted by GeneMO on December 02, 2007 at 12:29:54 from (216.74.196.145):
With the tractor (Super H) split, I was standing in front of the tranmission and while standing there I started putting the transmission in different gears. I noticed that in reverse, there was very little movement, but when you work the input shaft, going through different gears, the play increases to where you can move the input yolk several inches in each direction. Is this normal??
Man there is a lot of gunk down in there!! Top is comming off and in will go the Kerosene soak.
Thanks in advance,, Gene
