Re: super H oil gauge ?
Posted by El Toro on December 03, 2007 at 16:58:21 from (64.12.116.73):
In Reply to: super H oil gauge ? posted by gms on December 03, 2007 at 16:25:18:
If your new gauge has 1/8 male pipe threads you need a brass 1/8 coupling and a 1/4" compression
fitting to 1/8 male pipe threads. You install the brass coupling on the gauge and then install the 1/8 male pipe on the brass fitting into the coupling. Use a little teflon tape on the male threads. Hal
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
