Re: HAND CLUTCH
Posted by Andy Martin on December 03, 2007 at 17:37:13 from (63.99.111.164):
In Reply to: Re: HAND CLUTCH posted by Nat 2 on December 03, 2007 at 14:53:28:
Well, I still bale with a straight M even though I have an M with the hand clutch. It works good, but because of other operating issues we use it mostly for raking.
If you are baling in third gear with a square baler and the going gets tough, you can slip it into neutral between strokes and on into second without ever touching the clutch. When the hay lightens up, you can hit the clutch just after the plunger hits the hay and get right into third gear.
