Re: 560hydraulic pressure
Posted by GD720D on December 04, 2007 at 07:23:19 from (66.226.101.6):
In Reply to: 560hydraulic pressure posted by joe moyer on December 01, 2007 at 19:29:06:
The prerssure regulator is behind the cover on the aux. valves. Take cover off regulator is on the lower left side. It will have a cap with four bolts in it. Remove the bolts. It takes two different lenghts of bolts to get cover on and off bedcause there is a big spring under the cover. Might need to get a new gasket for cover. Add narrow rim washer under the big spring. I wouldn't go over 1500-1600 hundred psi. That system wasn't made for to much pressure
