Posted by Mixman on December 04, 2007 at 10:14:40 from (71.244.209.16):
Hoping someone has run into this problem and can help. I was asked to change the hyd. oil and filter on a 2444 with a 2050 loader on it. It has a auxiliary filter hung on the right frame support. I went to the local dealer and ordered a filter 547412R91. That is what it called for. It is the wrong filter and it had the wrong filter in it. There is another filter listed that is way to long. The filter it calls for is a little to long and too big in diameter. We have tried 3 dealers. I'm sure this is the filter canister this came with new.
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
