Posted by Slappy on December 04, 2007 at 15:51:51 from (70.149.213.193):
In Reply to: Farmall H Battery posted by Andy Motteberg on December 04, 2007 at 15:03:15:
Your battery should last longer than 2 or 3 months - even the cheap ones. If you used a single wire alternator for your conversion it will draw from the battery even when the ignition switch is off. Some are worse than others. If this is your problem and the alternator is drawing down the battery, you can fix it by using a float charger (I"ve seen them calle battery keepers also). They are inexpensive and will keep your battery charged even if you don"t use it for months.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
