Re: distributor reinstall
Posted by Bob on December 04, 2007 at 19:43:37 from (69.178.229.154):
In Reply to: distributor reinstall posted by Lance Trujillo on December 04, 2007 at 18:58:08:
#1 is at the FRONT, nearest the radiator.
Bring #1 up on cmpression stroke... you can feel the air being forced out if you SLOWLY crank it with your finger OVER the spark plug hole.
Between the point where air quits being forced out, and the point where you feel suction is TDC, the approximate location when the breaker points should JUST BEGIN to open to fire that (#1) cylinder.
If one of the high-tension terminnals is marked #1, use that terminal, otherwise any of the high-tension terminals will do, as long as you have the rotor pointing to that terminal, and the points JUST BEGINNING to open.
Then, arrange the remaining 3 wires, in firing order, following the #1 terminal, in the direction the distributor (rotor) turns.
That should be close enough to get it started, then touch up the timing using a timing light.
