Re: Super H, will have to wait
Posted by Hugh MacKay on December 05, 2007 at 04:31:27 from (209.226.247.131):
In Reply to: Super H, will have to wait posted by GeneMO on December 04, 2007 at 19:30:48:
Gene: All the best with the surgery.
This may seem like a bit of a glitch, however just think of the time you'll have carefully looking the tractor over, double checking your double checks. Often time these set backs just give you time to insure nothing is overlooked.
I learned a long time ago, if one going to play with old iron, never pays to be in a rush. Sometimes it just takes that medical condition to instill that in us. Again, good luck, and I'm sure you will be gracing us with your pressence very soon.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
