Like Hal said, clean the o-ring grooves. Make sure they're as clean as you can get them. If your sleeves don't have any pitting in the area that the o-rings seal against, you can reuse them, if in doubt don't take a chance on them, pistons and sleeves are cheap. I've always lubed the o-rings with soap, installed, and then installed sleeve dry, but I see no reason why your way wouln't work. Also make sure the counterbore in the top of the block that the flange of the sleeve seats in is perfectly clean.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
