Re: Winter Oil
Posted by Bob Kerr on December 06, 2007 at 09:20:10 from (64.12.116.73):
In Reply to: Winter Oil posted by Steve Mason on December 05, 2007 at 08:57:24:
If it has always had detergent oil, drop the pan and clean it out. There will be a lot of crud in there. My 1924 Olds doesn"t have an oil filter and never did. The book says to change the oil after 500 miles! They didn"t have detergent oil back then and the crud would settle out over night in the pan and usually stay there. The book said to drop the pan twice a year and clean it out. I bet most non detergent oil running tractors never had the pan cleaned or rarely at best. I use 10-40 in mine in winter, but I haven"t changed it yet. They run 30wt in summer and that is still in the H. It starts ok, but on a real cold morning it is slow cranking and everything like the battery and cables are in exellent shape. 10-30 or 10-40 will start easier in cold.
Today's Featured Article - A Lifetime of David Brown - by Samuel Kennedy. I was born in 1950 and reared on my family’s 100 acre farm. It was a fairly typical Northern Ireland farm where the main enterprise was dairying but some pigs, poultry and sheep were also kept. Potatoes were grown for sale and oats were grown to be used for cattle and horse feeding. Up to about 1958 the dairy cows were fed hay with some turnips and after that grass silage was the main winter feed. That same year was the last in which flax was grown on the farm. Flax provided the fibre which w ... [Read Article]
