Posted by Andy Motteberg on December 06, 2007 at 15:31:57 from (4.143.217.32):
In Reply to: Starting a sitting H posted by jlw on December 06, 2007 at 15:18:21:
Make sure the engine turns over and has compression. If it does not fell like it has much compression, add a small amount of oil into each spark plug hole. Make sure the plugs are clean and correctly gapped. Make sure the spark plug wires are in good condition. Look inside your magneto or distributor (whichever you have) and check the breaker points. Clean them off with a piece of fine sandpaper and make sure the points cap is set correctly. Put unleaded gasoline in the tractor's fuel tank. Watch the carburetor for leaks. Open the carburetor bowl petcock or remove the plug and see if there is a good flow of clean gasoline. If not, the needle in the carb might be sticking or the fuel filter or line may be plugged. Make sure there is oil in the engine. Put a little gas in each cylinder. Make sure the gear shift lever is in neutral and the brakes are ON. Set the throttle in the middle position. Turn on the choke, Turn on the ignition,Push in the clutch pedal and crank the tractor with the starter (if you have a starter) and see if it starts. If it runs for a short time, it may not be getting the gas. You would need to remove the carburetor, clean it, put in a kit and adjust it. If the tractor will not start, there may be no spark.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
