Re: Farmall 140 will not start.
Posted by Bus Driver on December 07, 2007 at 17:01:14 from (66.226.41.243):
In Reply to: Farmall 140 will not start. posted by John Danford on December 07, 2007 at 11:07:48:
While I do agree that the starter drive (Bendix) can get lodged in the flywheel, when it does and one tries to start the tractor, the amperage draw is tremendous and the lights would dim. I suspect a problem with or near the starter switch or that end of the battery cable. Will the engine turn with a hand crank? If so, the starter drive is not jammed. If the engine will not turn with the hand crank, the starter drive probably is jammed.
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
