Farmall 140 will not start.
Posted by John Danford on December 07, 2007 at 11:07:48 from (129.71.238.252):
My farmall 140 will not start. I have had it started only once for about 10 minutes. I drove it out of the barn. Then when I shut if off, it has not started since. The lights stay bright, and when you pull on the saddle switch nothing happens. The starter does not make any noise. I have had the starter rebuilt. The battery terminals get hot while trying to start tractor. But the tractor does not even attempt to crank. There is no noise from the starter or the motor. Thank you for your help.
