Re: H differential minutia
Posted by riverbend on December 08, 2007 at 09:55:49 from (208.160.33.176):
In Reply to: Re: H differential minutia posted by Gauger on December 08, 2007 at 06:50:32:
The replacement bearing is an SKF 212, has 14 balls (vs 15 in the one on the other side), made in the USofA. 60mm ID X 110mm OD X 22mm thick.
Thanks for the offer, but I bought a differential yesterday. It is the later version with the 65mm ID spigots. I am considering returning the bearing that I just got and getting two of the ST218A bearings.
The next issue is will the 218 bearings fit in my bull pinion shaft bearing cage? The cages are different between the band brake and the disk brake models. I can not find a cross reference to a standard bearing number for a st218. When I look at SKF's bearing charts, their 65MM ID bearings come in 100 and 120mm OD.
If you (or anyone) has a bull pinion cage or differential bearing (st218) from the 358054R1/358055R1 differential case handy, I would appreciate it if you would measure the bearing OD or the ID on the differential end of the pinion cage. If it is 110 mm (4 21/64") it should (might ?)all work.
Thanks
Greg
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
