Re: 674 Diesel hydraulics problem:
Posted by Fromjb2 on December 09, 2007 at 17:47:08 from (99.241.179.24):
In Reply to: 674 Diesel hydraulics problem: posted by Robert Hasserd on December 08, 2007 at 05:24:57:
Hi Robert, I kept a file of all problems/solutions for these models replied to by Bernard from Quebec. See below:
3 pt hitch problems:
Maybe the unload valve is stuck. Check with engine running, raise the hitch and pull the remote lever at the same time. If the hitch raises, you have dirt in the unload valve. This valve is under the seat and you remove the large plug for access. One trick, loosen the large plug, unload valve, 2 turns and start the engine, if the valve is stuck the hitch should raise. It has a small hole in the valve and just blow dirt out with compressed air. Replace the O rings.
Bernard le mécano Québec Canada
Hope this helps
JimB
