Re: 674 Diesel hydraulics problem:
Posted by Robert Hasserd on December 10, 2007 at 16:41:37 from (98.197.156.61):
In Reply to: Re: 674 Diesel hydraulics problem: posted by Fromjb2 on December 09, 2007 at 17:47:08:
Ok, you say under the seat below the dump valve. I removed the dump valve and there were 4 places for "O" rings and one looked as though it went to a solid block off area, is this the area where the tiny hole should be? I mean an area on top of the trans. Will this if it is cleared give fluid flow to the front end loader because it has no flow to the valve body. Thanks, Robert----
