Re: IH 300 starting problems
Posted by John T on December 09, 2007 at 18:38:27 from (66.244.83.147):
In Reply to: IH 300 starting problems posted by Jim Roberts on December 09, 2007 at 15:28:56:
Got spark?????? Pull the coil wire out of the distributor cap (leave coil end intact) and place its free bare metal terminal end to within 1/4 inch from tractor steel, turn her on n crank her over n see if shes sparking???????
So often non firing is cuz the points are bad, pull the cap n check the points gap and try to clean/buff/polish them if theyre not too bad or file slightly if burned n pitted n try her again.
If still no spark get a 12 volt test lamp or voltmeter n turn the ignition on and see if theres voltage on the coils lil input (NOT to distributor) terminal. If not check the ignition switch or temporarily hot wire the coil if the switch is bad n see if she fires then.
If it has an ignition ballast resistor between the switch but before the coil check to see if its bad/open??
If you need more post back n I will post my entire Troubleshooting Procedure for non sparking
John T
