Re: IH 300 starting problems
Posted by Jim Roberts on December 10, 2007 at 19:09:34 from (207.199.252.103):
In Reply to: Re: IH 300 starting problems posted by John T on December 09, 2007 at 18:38:27:
I tried the plug trick and there was no spark. I then pulled the distributer cap off and tried starting the tractor again and the rotor does not move at all. The distributer should be geared to the engine so that when the engine is turning over the rotor should turn. Correct? To me this would suggest that the shaft of the distributer is broken or I have broken teeth on the gears. there is no grnding noise so I am thinking the distributer shaft. What are your thoughts?
