Re: Super C oil changed and more...
Posted by teddy52food on December 10, 2007 at 06:31:11 from (209.237.111.169):
In Reply to: Re: Super C oil changed and more... posted by Steve Mason on December 10, 2007 at 06:12:59:
If it still has that short ground cable hooked to the box under the steering post, it is not getting through all those old rusty connections. Get a longer cable to go from the battery to the starter mounting bolt. Are you holding the clutch down? If not, it will turn harder because the transmission oil is stiff.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
