Posted by Wardner on December 10, 2007 at 14:31:11 from (4.154.242.208):
In Reply to: Re: need HP RPM posted by Hugh MacKay on December 10, 2007 at 02:31:14:
He could fix the TA, install gears (mainshaft and bevel along with first gear) from a 460 or 504, fit smaller tires and wheels, and it would still be too fast and underpowered. He needs a hydro.
Now, if he had a 400, he could do all of the above using 560 components and 660 planetaries and he might have something. I am not going to do the math, but I bet top speed in fifth direct will be no faster than 8 mph. Creeper gear at rated rpm might be 1/2 mph.
I have done the above, less planetaries, on a SMTA and have a top speed of 11 mph.
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
