Congrats on your new tractor! Chances are that if you have a six volt system with a generator (not an alternator) that your system should be postive ground (it was originally). Changing it back (if the previous owner simply installed the battery incorrectly) will be more difficult as the generator and regulator may be damaged and will certainly need to be polarised (hopefully someone else will post the correct procedure). Also have a look at your coil polarity. It should be the same as the rest of the tractor (treat the side going to the points as ground).
You may also want to go and take a look at the following link (trying something new, so I'm hoping the link appears). Hope this helps, tractorsam
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
